Ariens GT14 hydraulic lift question
ChuckGT
Hi, I have an Ariens GT14g tractor with a snow blower attachment. The hydraulic lift is a little erratic. Doesn’t lift up like it should. I tried filling the hydraulic reservoir but the oil doesn’t seem to go in. It just spills it out through the opening as if it’s full even after i drained it. I’m not sure why the lift is so erratic if someone has an idea, and if I need to refill the oil in that reservoir, how exactly do i keep it from spilling out the top. Is there a vent of some sort? It’s the reservoir below the floor plate. Thanks.
