Repairs Anyone know the size of rear axle key
farmerdoc
for Sabre (don't laugh) 1642hs?
KennyV
farmerdoc...
Hello and welcome to the group...
If it is this Saber and item #6 in this drawing it's 1/4 X 1/4 -12...
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
It this does not look right put your model number in the box and drill down to the trans/ axle parts diagram... after you select the part into your 'cart' you can then go to your cart and it will have a more complete description... Hope this helps, and you get your 'low' hour JD going soon... :smile:KennyV
farmerdoc
farmerdoc...
John Deere - Parts Catalog
Thanks. I've found it and will pick up at my local JD dealer.
