Hammermechanicman
- Jan 10, 2020
- 49
- 3,485
I used to keep a hand written daily diary when I was told to do anything I thought was against my better judgment - just whip it out when things went south - always came to my rescue when finger pointing started after failure- no one else had anything to fall back onOr could had supervisor like I once had where he do something to a machine I was working that I told him would destroy it. His first order was do it because I said so. Well after it destroy the $2000 programmable calculator he turns to and "you knew better but you did anyways" then tried billing me for the damages. He never got paid as it was on him.
Shock mount in front of spark plugs so that once you break the plugs loose you can't use a socket to get them all the way out. After 2 turns you can barely get the socket off and finger the plugs out. If they aren't tight. I'll bet the engineers used to work for Chrysler.
So true. Then if they ever tweak something enough to get out pretty darn good, they will change the model number and make a "new' one and screw this up again.View attachment 63036
