PTmowerMech
- Apr 16, 2018
- 396
- 3,016
Seriously, I went into a pond on my landlords zero turn.
I'll post pics when I get a chance. I was mowing in places that weren't too wet. The top of the ponds dam was dry. My front wheels were dry. I went to turn around, when suddenly the drive tires started to slide towards the water. It was sloped towards the water, but the slope wasn't real steep. None the less, once it lost traction, it was a goner. From where I lost traction to the water was at least 10 ft.
About 1/2 way, I was facing land, both levers pushed all the way forward (scared out of my witz). That didn't work, still sliding backwards. So I kill it, and pull the E brake. Still slid backwards into the pond.
Only thing out of the water was the front wheels. In like 2 or 3 minutes, I was out of the water. Another 5 minutes was draining the oil, removing the spark plugs and oil filter. Turned the machine around so that the drain was at the lowest point.
Had to drain the carburetor, push out the water in the cylinders by turning it over, and a few other things. But It's back to running. Everything seems fine. keeping a close check on the hydro's reservoir.
Luckily, my landlord didn't see it happened. I told them what happened, and they were cool about it. They're such nice people.
