Alignment issues using adjustable Drag Links
Derryl
Hi, just replaced, Spindles, Sector plate, drag links(adjustable) on my JD LA120 as one drag link got bent. Used the Caltric kit on EBay. Both drag links are cranked all the way in…no adjusting…but I can’t align the wheels, one wheel bows out. Triple checked installation…Spindles are on the right side(did swap to check), drag links point out and Sector plate is centered. I’m kind of thinking the adjustable drag links p/N: DL101 & DL102 are not the ones for a JD LA120.Spindles matched the old one I took off. Thanks for any help and advise you can offer.
