Agco Allis bevel gear box
johnorlandi
Hi guys need your help see my post under Simplicity and Allis Chalmers on Agco Allis 918H bevel gear box
Does anyone have instruction on how to remove the bevel gear box? I have almost all the bolts out and still it won’t drop down.
Does the bolt #157273 stud for the handle to tighten the belt from the rear have to come off, I put a wrench on it, and I could not budget it? May have to use heat!
I purchased a used bevel gear box and will install this one.
The last gear box broke the shaft # 1685054 (shaft Driven) in 6 months with very little time on it.
Price new tractors and they are out of sight will not spend that kind of money at 83 years of age.
Any help would be appreciated
Thank You
John
