Agco 912 PTO
johnorlandi
I have an Agco Allis 918H that I had the dealer repair the PTO at a cost of around $600 and it worked good thru the winter with the snow blower on now I have the mower on and having a problem with it slipping real bad, so bad the clutch go so hot it burned my hand. It is at the dealers again. New clutch has some black type band inside replacing the original brake band
Would like to know if anyone has rebuilt the clutch and what did you use for material and where did you get it?
Thanks
John
