How do you adjust the valves on this trimmer? I have the gauge.
B beretta22 Member Joined Aug 25, 2022 Threads 16 Messages 44 Sep 23, 2022 / Adjusting Valves FS 130R #1 How do you adjust the valves on this trimmer? I have the gauge.
StarTech Lawn Royalty Top Poster Of Month Joined Feb 19, 2020 Threads 79 Messages 10,264 Sep 23, 2022 / Adjusting Valves FS 130R #2 Rotate until TDC compression stroke. Note the following only show aligning the arrow which can occur on the non compression stroke.
B beretta22 Member Joined Aug 25, 2022 Threads 16 Messages 44 Sep 23, 2022 / Adjusting Valves FS 130R #3 Thanks, I found the idle position and adjusted the clearance. Pulls much easier. Now need to replace the rewind spring.
