I need to adjust the float. Do I just use a needle nose pliers and just bend it up? I have been dealing with this issue for a couple weeks, finally figured out float is not letting gas in fast enough to keep up with mower needs. I did find an easy way to there is a problem with the float, Turn carb upside down and see if you can blow air through gas inlet, if you can the needle is not seating, turn carb right side up and blow into gas inlet, should be able to blow air with out much obstruction. On my particular carb I can get air to enter through the inlet however does take quite a bit of effort, I need to adjust the float a little more.
