942295E Drive issues
Pete _Miller
Thanks in advance for any and all help. My bobcat zero turn mower has an issue with the drive. I have one wheel the left side does not get traction. The drive motor works but the wheel constantly spins, not getting traction. Could the frame be bent? Is there an adjustment for this? Thanks Pete
Yes it could
double check your tyre pressures and drop them by a couple of PSI
The frame around the deck with the casters is the bit that gets bent but it is worthwhile to have a good hard look at the transmission mounting bolts and the brace that runs between them
