I ran my JD216 after 'bout 18 months. Added gas, not completly empty.
Cranked/ran fine for about 45 minutes. Lost power & died.
Bottom line, fine surface rust in carb bowl was only possible problem I could find.
Fuel to carb, compression, Ignition - good.
I removed bowl/float & float valve, idle and main fuel valves. Did not remove welch
plugs. Soaked parts in carb cleaner. Assembled w/ new gaskets per Kohler(factory)
parts manual. Wrong (compared to orig.) inlet needle valve in Kohler kit. Used orig.
valve looked good. Installed carb. Cranked, idled for couple minutes. But gas flowing
through port in inlet throat. See image. And began to die out.
Could rust particles be in uncleaned cavities with welch plugs in place?
Any suggestions.
Any suggestions.
