8 HP tecumseh chipper, replaced Carb, Fuel line, spark plug, it has spark, but STILL won,t start
greenhouseguy
  • / 8 HP tecumseh chipper, replaced Carb, Fuel line, spark plug, it has spark, but STILL won,t start
What else could there be?? I poured gas into the cylinder and best I could get out of it was a backfire no start and run partially and die .... nothing!
upupandaway
"best I could get out of it was a backfire" That may be your problem. Take off the cylinder head and see if the valve(s) are closing. At Top dead center with both valves closed, try to turn the valve. if it easily turns, the valve is stuck open. If so, remove the valve, check the gap,grind down the valve gap down to spec as needed.
greenhouseguy
OK at least I have something to try, I figured i would have to go deeper, now any tips to where I get the engine specs?
Scrubcadet10
Moderator
Staff member
You will need the model number, if it's a tecumseh flat head, it's usually stamped onto some sheet metal by the spark plug
Had anybody checked the flywheel key to see if it is sheared. Wrong timing from sheared key will cause issues also.
