8 hp briggs needs carb overhaul kit
old blue
I have a older B/S 8 hp that needs a rebuild kit. my problem is my fly wheel cover has no model # or serial# readable, if it is even the right cover. here is the question, are all 8 hp briggs carbs the same if so does anyone know where to order one on line. thanks
No, not all 8 hp engines use the same carb. If you can take some close up pics of the carb it would help us help you.
old blue
thank you will try to send picture as soon as I figure out how to. Not good on computer.
