777
777
I have a toro proline recycler 21" model 22043. recently I've noticed a popping sound coming from the back axel when the self propel is activated. Any ideas? Thanx
Check to see if you have a worn wheel gear or drive gear. When was the time you had the drive system cleaned and lubed?
