72'' Lazer Z XS Diesel Won't Start
Maxx27
I have a 2008 72'' Lazer Z XS Diesel that will not start. There is no power to the glow plugs and the engine won't turn over. The battery is full charged and none of the fuses are blown. It seems like I am not getting power to anything.
Bertrrr
Check your ground wire first , then test voltage at the starter solenoid, ignition switch etc.
A little history on when this took place and how it's been running prior as well ,
And the exact model number off the ID tag so we can pull down the wiring diagram .
Basically you need to start at the beginning and trace power starting at the battery
Check both to the mower ground & the battery -
Remember all electricity has to make a complete loop
No ground connection = no power anywhere .
Maxx27
The ground wire is good and the starter solenoid has power to it. The ignition switch has no power going to it. The model number is LXS25KD725. In the past I had to replace a throttle solenoid because the mower would keep shutting down after a few minutes of running. After I replaced the throttle solenoid it was running good for a year and now it has completely stopped working.
