68 Deck pulleys
Dannnnn
Can anyone tell me where I can purchase pulley bearings/assembly for 68 deck. A684H 098705 M?
reynoldston
I am finding out the same thing you are. Parts for the model 68 is getting harder to find. The first thing you need to do is measure then. Shaft size, outside diameter, and width. You should be able to buy them from anyplace that sells bearings like NAPA. Some times you can find a bearing number on them and they can also go by this.
reynoldston
If you need much more then bearings maybe a mower salvage yard, parts are just getting hard to find for the old model 68.
Briana
Hey there - WELCOME to LMF!
I moved your thread to the Small Engine & Mower Repair Forum. :smile:
oldyellr
If that's a JD Model 68 rear engine rider you're talking about, go to a JD dealer. I replaced one of mine last year and the new one was for a later model and used a spacer.
