6.5hp OHV Coil source 0G3231 ?
Rollin
Anyone have a replacement number for a 0G3231 coil? It's discontinued, was reading that coil #2 (0G3224BSRV) from a V twin may work, maybe not. Very nice pressure washer, I'd hate to scrap it for a coil. Thanks !
My generac distributors shows NLA and no alternative.
Rollin
Thanks, I'm getting the same NLA response. Hard to believe there isn't something that will work, it's not that old.
I used to work on those units years ago. These two sites might have what you are looking for, but no guarantees. I understand your frustration, hope you get lucky.
Scrubcadet10
Moderator
Staff member
of all of the things the chinese copy they couldn't copy this?
gene_stl
I am having a similar problem for a coil for a 6.5 hp OHV Briggs. It is no longer available. They mention replacements and I bought one but it did not fit.
Some of the numbers discontinued are 799471, and 793352 which they claim is superseded by 591420.
But that one does not fit, the mounting screw holes do not match up.
on fleabay db electronics shows this item which looks pretty much like the original.
The probably have the one you need too. I doubt they are real briggs but so what. As Taryl says "it ain't th space shuttle"
I have ordered one of the above. It was half the price of the Briggs superseded part. (21 vs 41 dollars US) I will report how well it works.
Scrubcadet10
Moderator
Staff member
I've had good luck with DB electrical parts.
