- Nov 29, 2014
- 64
- 24,647
Back to this 9p702 0127-11 engine which was giving me grief
Do any of you have problems with the breather reed valve ?
Does any one know how sensative it is ?
should it work when slowly rotating the engine by rotating the blade by hand or does it need substantially more inertia
Point being the mower I just sent back had a new air filter fitted by the owner last year.
When I tried to start it today i would not run with the filter on .
The filter was fairly clean but did have a lot of oil & fuel in it so I am starting to think that the reed valve has failed or is stuck open.
Same story that would have been more labour to check it than the customer wanted to pay for but a new plug & filter annually is fine
