Hello. I just picked up a 5024 for cheap and its reving high. When i turn carburetor adjustment knob clockwise it keeps running hard but will die once its nearly turned all the way in. If i attempt to back it off the mower will sputter and then start to over rev again. Its like there is no sweet spot. The engine also is pushing gas out of the carb which i assume is a float issue. Not sure if the two are related. Any tips are appreciated. Thanks
