I recently blew the head gasket on my 5 horse Little Wonder blower. The engine model is 130202 3104. I de-carboned the head, piston and valves, and replaced the head gasket. It started great, but I noticed that after about 5 minutes or so, the engine's power would drop to ~70% or so. The valves looked OK so I did not do anything to them during the gasket replace. I don't have a compression gauge so I could not test. Is that a likely culprit? Any other ideas of what could be causing the performance drop? Thanks!
