curmudgeon555
- May 9, 2018
- 3
- 19
Replacing carb and now not sure how throttle linkages hook up. Throttle bracket (691366)does NOT have the nylon slider seen on other bracket videos. B&S engine is 42E707, type 2031-E1. Carb is 19306
Throttle cable is secured to clamp on intake manifold and the Z wire extends toward the carb.
Manual choke wire attaches directly to carb choke arm
Carb has plastic L shaped arm with holes on each leg, attached right next to the throttle plate lever. Perhaps throttle wire attaches to one of these holes and a small metal link attaches L lever to the throttle control lever??
That leaves one longer metal link to attach (I guess) to the governor control mechanism.....but where?
I have photos of things mentioned, but having problems attaching here. Email your address to gludwick@bellsouth.net
Any help or directions would be appreciated
