Rpgowned
- Apr 30, 2021
- 3
- 14
Okay so I am having an issue where my engine is running extremely rich and when I kick on the mower it chugs and barely runs.
My first troubleshooting is that I replaced both plugs, didn't work.. so I also ended up replacing the carb and fuel pump only to after that didn't fix it, I noticed one of the brand new plugs (left) was sooted up already. So I unplugged that plug and the mower didn't start at all. Plugged the left back in and unplugged the right and it ran exactly as if both were plugged in. At this point my assumption was a bad ignition coil so I replaced the coil on that right side.
However, that also did not fix the issue. Runs like shit and very rich with the left side only and not at all with the right side only.
Any idea what else the problem could be?
