- Nov 29, 2014
- 64
- 24,705
OK fellas, I am stuck with this one
Got a 345 in the shop
originally it had a broken piston which killed the bore as well
Replaced the barrel , piston bearings & seals
Saw runs perfectly
But not a drop of oil to the bar
1) pressurised the oil tank & oil ouzed out around the rubber seal, so replaced the seal-no change
2) replaced the spindle - no change
3) removed the filter , it was clean
4) replaced the entire pump, worm gear & another rubber seal, still no oil
The only non standard thing is the drum which is now a rim sprocket in place of the spur sprocket , but I have checked the drum is triving the oil pump worm gear
This has the cheaper pump with no flow adjuster .
As this is mainly a mower forum I have also posted to OPE
I would rip my hair out but it is all gone already .
Any one got some ideas ?
Saw runs perfectly
