CWBond
- Oct 1, 2020
- 1
- 1
I have an issue with my transaxle. Right now, it won't go forward or reverse. If I toggle the bypass lever it acts like it wants to go, but then nothing. So sounds like a center section issue from everything I have read and researched. BUT, It was working fine. I had to replace a bearing and seal on the axle shaft. Essentially all I did, was drain the oil, remove the rear cover, remove axle, replace bearing and seal, reassemble, and purge IAW instructions in the manual. I have repeated the purging procedure over and over, and feel like there is something I am missing. Decided to reach outfor help before I pull all my hair out. Thank you in advance!
