I bought a 1978 B&S model 92988 Mountfield mower which was hard to start, missed almost regular beats at all speeds and wouldn't run at low speeds. So I looked into it. Now it won't start at all and has no spark, but it did fire just once with a cloud of smoke.
The 2 wires to the condenser had been cut out, so the magneto was an electronic replacement. It has 9504P marked on it but I can't find that online.
Its 2 wires have a resistance of 0.9 ohms and 4.5 kohms.
The kill wire is not shorted to ground and the meter shows over 1000V (its limit) when connected to the plug cap with the plug out. I've tried 2 mower plugs and a car plug with its gap reduced to 5 thou but no spark.
The flywheel has 3 magnets that will support a fair size screwdriver so that seems OK.
The parts manual shows a 398593 and another magneto 209812 with a trigger unit for this motor. I assume that 398593 is electronic as it uses 398593 for the part number of both the combined 209812 and trigger, and that combination is electronic.
If 398593 is the correct magneto, will any of its replacements be OK?
Unfortunately I just got rid of a 1979 model 92982 Mountfield mower as the roller drive shaft broke, otherwise I could have converted it back to points.
Any help would be appreciated.
