28 hp van guard surging
gregjo1948
28 hp Briggs Van Guard with EFI is surging. How do I adjust or repair this problem? thank you, gregjo1948
mechanic mark
Post your engine model xxxxxx, type xxxx, trim xx, code xxxxxxx numbers. Are you using 93 octane gas with fuel treatment to take care of ethanol problem ? What brand of fuel treatment? Stay away from Stabil fuel treatment.
See Repair Manual, you will need a code reader or back to Dealer for repairs.
gregjo1948
49E877-0005 With a compression ratio of around 8.5 to 1, these engines don't need high octane gas.
mechanic mark
I disagree with you. I use 93 octane gasoline in everything from pickup truck to outdoor power equipment. I use 5w-30 full synthetic oil in my Vanguard engine per instructions in Operators Manual. I suggest you carefully read your engine manual. Vanguard Big Blocks use 15w-50 full synthetic per recommendations in Engine Manuals. I also use B&S OEM parts for my Simplicity lawn tractor.
