I have a 25 Hp.Verticle B&S engine (model 445777-0168E Code 021125YC)I cannot get it to run on both cylinders, If I pull the plug wire from #1 cylinder it makes no difference, If I pull off #2 plug wire it dies. I have swapped plugs, swapped coils, still #1 is doing nothing. I have 150# compression in both cylinders and No intake leaks, I took carb apart everything seems to be clear and clean.any ideas?
Thanks
Thanks
