PTmowerMech
- Apr 16, 2018
- 391
- 2,996
With a Briggs 33R877 0007 G1
Pulled the kill wire and it starts right up. Plug it back in, while it's running, and it dies.
So I removed the clutch safety switch and the PTO safety switch and tested them. Both test good. I pulled the clip out of the 4 pole seat switch and plugged it back in. And still can't get it to start. When I pull the kill wire, it fires right up, with no hesitation.
With a test light, I checked to see if there was juice going to through the kill wire. Not even a flicker while it's running or when I kill it.
Funny thing, when I turn the key off, after a couple of seconds, the engine dies.
