Yes Kolfsr you need to find a head or gears for an engine that spins the same way as yours
The other alternative is to put the shaft & head from a bent stem trimmer on it but if you do then it can only run string and no blades .
You might find either a head or shaft set in the EU as old shelf stock in a dealer or engine repair shop ,
All of the honest web sites , that check is a part is available from the warehouse list it as obsolete - NLA - Out of Stock etc
The ones I know are dishonest who take my money then put an order on a warehouse list it as " ships in 2 to 4 weeks "
Good luck .
