22 hp briggs using oil
meyerdawg
my 10 year old briggs 22hp is smoking and using oil i adjusted the valves the right side cyl plug is oily no sign of oil leaking are the rings shot?
Fish
Probably has a leaking head gasket, if your oil level isn't over full, and the oil doesn't smell like fuel.
meyerdawg
thanks fish if im taking heads off to replace gaskets should i do rings anyway
motoman
Careful, "doing rings" without proper attention to cylinders is money thrown away.
