Happened to me too. Supposedly a lot of new Ferris this year were under greased. If you put the zerk fittings on, you'll need to pump a whole lot of grease on there to fill the tube, otherwise the grease won't reach the bearings. I ended up popping the black cap off and put a mixture of grease and gear oil in there.
