2021 Rogue PTO Clutch bolt torque value
Coastie
I had an old Cub Cadet which required a specific torque value on the PTO Clutch to avoid excessive wear, is the Rogue the same way?
What is the torque value for the bolt that holds the PTO Clutch on?
I haven't seen a service manual online that has details like that, is there an online/pdf service manual available anywhere?
Yes it need to be torqued properly here is three of the common PTO screw torque values.
Also make sure your torque wrench is calibrated properly. I just had to re-calibrate a customer's Craftsman 1/2" drive torque wrench. With initially set at 45 ft/lbs it was clicking at 39.5 ft/lbs.
Coastie
Thanks, I appreciate that.
