2021 Elite -Locking right rear tire up on tight turns
allmotor408
  • / 2021 Elite -Locking right rear tire up on tight turns
Hi guys,
I have a 2021 ZT Elite that's locking up the right rear tire on tight turns. It'll do it on pavement or grass.
If I go to turn right there's no issue.
Do you think that may be an issue with a hydro needing adjustment?
Thank you
hlw49
Could be you are unconsciously stopping the wheel on a left turn try doing a three point turn and see if this cures your problem
Check the tyres & body paint for signs of rubbing
The transmission might be coming loose & locking against the body.
