2019 3200 won’t turn over after washing
JayPrat
I pressure washed my 3200 with 37 hp Vanguard and three days later won’t turn over. Sat on it, all switches should be closed yet only the red light goes on. PTO clicks, nothing? Any advice?
Find the starter solenoid and make sure that the thin trigger wire is on the tab and the pressure washed did not blow it off .
If it is on there check if you get 12 V between it and ground with the key in the S position.
If no voltage , check the fuses and if they are OK check all of the elecrical plugs to see if one has not come loose enough not be be making proper contact.
