I purchased this mower new in 2013. Haven't had any problems until last week. Drained the gas and ran dry and then added a gallon of fresh gas + Sea Foam as I do at the end of each season. Ran her 5 minutes to circulate gas on 11/2019. Put in fresh gas last week and she cranked as new with strong battery but wouldn't start. The red oil light comes on as normal when the switch is turned and cranks well. The lights work and the voltage meter and hours meter so I don't think it is a fuse. I cleaned the plugs and it still didn't start. I took the hose off the fuel pump to the carb and no gas is coming out when I cranked her so I ordered a new fuel pump. There are 3 hoses to the pump. One from the fuel filter, one to the carb and another goes under the engine. Any advice other than wait and see if the fuel pump is the problem? Thanks for reading. Pochie
