Tiewarrior
- Jul 22, 2021
- 1
- 1
The starter melted the fuse holder and that was replaced, along with the starter solenoid, ignition switch, starter, and a new fuse holder. I used the blade-type automotive connector to install a new fuse holder. All safeties have been checked and verified with a voltmeter they are functioning as they should along with the relays. Verified all coils on relays were good. When the key is turned on you usually hear the relays engage, and now you do not. When you attempt to start it nothing happens. I have had the key on and you can jump the solenoid and the engine turns over but will not fire. Any ideas? Bad wiring somewhere?
