Have changed the carburetor 4 times in last month, first one the throttle pivot hit the block so I sent it back and put the old on back on and it ran good for about 30 minutes and found that the engine was flooding out and when it cooled, I could drive it back to garage. (You can't push or pull a zero turn when the engine is dead.
I tried it again and it ran for about a half hour and the same thing happened. I ordered another carburetor put it on, it idled great for about 15 minutes and when I went to drive it, the same thing happened flooded with gas. Finally I put vise grips on the hose and almost clamped it off so I could drive it back to the garage. I am afraid to drive it anywhere because of the heat and not wanting it to break down away from the garage where I can work on it. Has anyone else got a possible fix for this.
