1990s is3000Z engine replacement
JohnW63
My ferris needs a new engine and am considering a Kawasaki FX EFI model. The original engine is FH721V.
Firstly are there any modifications required to the existing wiring loom if a fuel injected unit is added or should I stick with a carb model?
Model no FX730V EFI has a little less power and torque to the original and FX850V EFI has a little more - additional 4.5 ft lbs torque although I’m yet to check if the 850 fits, it’s a few inches larger all round. Any issues with additional torque?
I appreciate some advice. Thanks.
