OKThat’s what I figured, but my literature says down to 4 hp. That’s why I want to double check using his OEM original coil numbers.
The model no. is 80332, Type is 0474-02 and code is 78030203, again thanks for the help.That’s what I figured, but my literature says down to 4 hp. That’s why I want to double check using his OEM original coil numbers.
