18 ohv Intek new head
Michgem63
I have just replaced the head on my B&S 18 HP ohv Intek. Everything went smooth. Went to start it now the compression is so high the starter will not crank past top dead center. I can turn it past by hand (with lots of force), then try the starter again only to have it stop again. Bought a new 340 amp battery no help. Any ideas??
sgkent
pull the spark plug and see if it is compression that is the issue or mechanical binding
Scrubcadet10
Moderator
Staff member
Did you adjust the valve clearance?
