Poulan Pro 42" 18.5 hp intek ohv
Where to start? Or should I say HOW to start. I put in a new battery, air filter, fuel filter, oil filter, spark plug, cleaned the carb, bowl and float. Still wouldn't start. So I did some asking and looking, was told to adjust the valves. Did that. .004, both intake and exhaust. It finally started. Drove it for about 20 ft. and it started to sputter a little. So I tried playing with the choke, which didn't help. I shut it off and now the son of a motherless goat won't start back up. It's acting the same way it did before, it doesn't want to turn over. I know that it's either something I did or didn't do, but that don't quite narrow it down enough. Can the valves get back out of adjustment that quick? Any ideas would be appreciated.
