While you are at it....
1.Have you ever pulled the metal engine shroud and cleaned the top of the block and cooling fins? This is a yearly maintenance item in ALL engine manuals. Neglect this and you are looking at engine damage.
2.Need to pull the head. Remove all carbon from the piston face, head and valve area. Chunks of carbon will flake off getting between the piston and rings. These ultra hard chunks will gouge the cylinder bore causing the engine to smoke. Should be done say every 3-5 years. Depends on how much you mow. Commercial lawn crew, more often. Home owner say every 5-7 years'ish.
Verify which valve is which so you are confident you are on the proper TDC stroke. There are 2 TDC strokes in a 4 stroke engine. Double check yourself......
