Gentlemen, what 16 1/4 high lift blade is rated to have most lift you can identify ? thanks, Ray
R RayMcD Well-Known Member Joined Sep 14, 2021 Threads 44 Messages 259 Oct 11, 2022 / 16 1/4 high lift blade ↑ #1 Gentlemen, what 16 1/4 high lift blade is rated to have most lift you can identify ? thanks, Ray
7394 Lawn Addict Joined Sep 5, 2014 Threads 84 Messages 4,718 Oct 11, 2022 / 16 1/4 high lift blade ↑ #2 Are you measuring on the diagonal, like a TV set.. Would be closer to 16.5"
R RayMcD Well-Known Member Joined Sep 14, 2021 Threads 44 Messages 259 Oct 12, 2022 / 16 1/4 high lift blade ↑ #3 7394 said: Are you measuring on the diagonal, like a TV set.. Would be closer to 16.5" Click to expand... Buddy, blade is for a Bobcat 48" CRZ, 16 1/4". r
StarTech Lawn Royalty Top Poster Of Month Joined Feb 19, 2020 Threads 79 Messages 10,264 Oct 12, 2022 / 16 1/4 high lift blade ↑ #4 Check out Rotary 9487 or 14538. Longer air lifts.
7394 Lawn Addict Joined Sep 5, 2014 Threads 84 Messages 4,718 Oct 12, 2022 / 16 1/4 high lift blade ↑ #5 ok..
