15 or 20 amp fuse
Cscott
Have a new Bronco. Used it for about 45 minutes before it stopped running. Discovered the 15 amp fuse on the battery harness blown. On line manuals states a 20 amp fuse is most common. Which is the correct fuse? Anyone had this issue?
I would use a 20 Amp fuse, as this is probably in the charging circuit.
Cscott
Thanks for the reply. I was thinking the same, But I’m not a mech. I was a boat driver, I took what my engineers said as the gospel.
