Hi all, nice forum posting because my troy bilt tuffy has a loose drive belt and put a new belt on kinda worked but not all gears only higher gears now barely moves in 7th gear.
here is a schematic of the tractor for reference. It doesn't really have as many pulleys as newer tractors as seen in diagram.
Troy-Bilt 13AN689G766 - Troy-Bilt Tuffy Lawn Tractor (2004) Drive Diagram and Parts List | PartsTree.com that is the drive scematic
here is the drive control rear wheels, the belt slipps in every gear now and I though maybe there was a spring missing or a pulley? But hopefully someone here has had the same problem to fiuix, read about adjusting the control arm? Well here is the schematic
Troy-Bilt 13AN689G766 - Troy-Bilt Tuffy Lawn Tractor (2004) Drive, Controls, Rear Wheels Diagram and Parts List | PartsTree.com
Ill be watching the forum closely for any answers your input is really appreciated thanks again Also took cover off of the rear and watched the drive belt it is really loose. And oputting it in 7th gear really doesnt tighten it that much.
Bob
Bob
