13.5 HP B & S Runs rough under a load
Jerryb
4 to 5 year old Craftsman mower with a 13.5 hp B&S starts good, runs good. Until I engage the blade, then it runs rough and blows black smoke. If I return the throttle to an idle it will smooth out. I can slowly move the throttle to about halfway before it goes to running rough again. Rebuilt carb, set valves and governor.
Mikel1
Post up your engine #'s and Craftsman model #.
Jerryb
Thanks for the reply. Fixed it yesterday. Even though the carb looked good, I replaced it and the problem went away.
Mikel1
Sounds good, glad you got it fixed.
