11hp briggs & stratton I/C engine codes
ZOMBIE01
Hi all I have inherited a old briggs and stratton 11 hp synchro balanced I/C engine which came off a old westwood tractor mower. the carburettor is siezed solid and the main jet has been stripped so a new carburettor is needed am I correct in thinking the model number is 253707 code 85071511 type 0168-01. So should I look for a 253707 model carburettor. It has good compression clean oil and no metal flake in the oil also it has a good spark am I to belive this engine does not have points but a ignition coil ?. Its filthy but seems a good solid engine. I am building a pull behind mower so what thoughts please and a happy new year all
ZOMBIE01
Many thanks for this as a novice in the world Briggs & stratton this will get me on my way cheers and have a great new year
Every engine we assist in repairing is another new engine that is not being made.
Thus resources are not being wasted so we end up saving the planet one engine at a time which is more beneficial than walking down the streets chanting slogans carrying a placard .
