I tried running this generator without the fuel pump. It痴 a little hard to start, it runs for about 5 minutes pretty good and then it starts popping a couple times out the exhaust, starts sputtering, running erratic and then dies. I知 thinking its leaning out. It does the same thing after doing the following things, ran it without the cap on the tank to check venting, tried new fuel filter, cleaned carb and jet two or three times. I ran it with and without air cleaner. I ran it with oil switch disconnected. I really think I could fix the problem if it had a air/fuel mixture screw on the bowl. I don稚 know what else to check, so I知 thinking about buying a new fuel pump for it although I think it should run without one. I知 thinking these carburetors originally were calibrated close to the lean side and now with 10 percent ethanol in the gas and the slight change in fuel pressure this thing is running a little lean. Any other ideas? Thanks
