Had a problem with the starter coil so I replaced with new and started ok but ran really poorly. I neglected maintenance on fuel last fall so I figured ok so I drained the old gas from tank and carburetor. New gas - same problem. Took carb off for thorough cleaning and when I was going to put it back together I dropped my bin of parts. Found most, but not everything. Got mad and ordered new carburetor. Installed and started just fine but for the first minute or so it spits and sputters until the engine warms up. After that it runs perfectly. What adjustment am I missing?
