Hello,
I am new to the forum. I was wondering if anyone knew a alternative to the $1,150.00 White Drive pump on a 08 Dixie Chopper Silver Eagle HP SE2760. That is made by White pumps only for this model Dixie Chopper. You cannot get parts other than a seal kit for this particular pump so says Dixie Chopper and any hydraulic company that works on white pumps that I have talked to. I had a bearing go out in the same pump and found a bearing for it at a local bearing store and purchased the seal kit and replaced it myself. I noticed wear on some other parts in the pump but it lasted three years after I fixed it. Now the pump has gone out. Lap bar is froze up. The only fix I can find is purchased the whole pump. Does anyone know an alternative pump just as good as the original that you can at least get parts for it. I hate to replace the pump with the same pump that I cannot work on.
Right Drive Pump
White Numbers
Make # White
Model # 101013000007
Serial# 101013000007000612
Dixie Numbers
Make # 08 Dixie Chopper Silver Eagle HP SE2760
Model # 200109 Left 200110 Right
Thanks for any help
Right Drive Pump
White Numbers
Make # White
Dixie Numbers
Thanks for any help
